RenderTypes.hh
shared_ptr< Object > ObjectPtr
Shared pointer to Object.
Definition: RenderTypes.hh:207
shared_ptr< const Material > ConstMaterialPtr
Definition: RenderTypes.hh:345
shared_ptr< const Sensor > ConstSensorPtr
Definition: RenderTypes.hh:401
Represents a billboard text geometry that is always facing the camera.
Definition: Text.hh:62
shared_ptr< RayQuery > RayQueryPtr
Shared pointer to RayQuery.
Definition: RenderTypes.hh:223
shared_ptr< SubMesh > SubMeshPtr
Shared pointer to SubMesh.
Definition: RenderTypes.hh:261
shared_ptr< const PointLight > ConstPointLightPtr
Definition: RenderTypes.hh:369
A LidarVisual geometry class. The visual appearance is based on the type specified.
Definition: LidarVisual.hh:55
shared_ptr< const Image > ConstImagePtr
Definition: RenderTypes.hh:333
shared_ptr< Geometry > GeometryPtr
Shared pointer to Geometry.
Definition: RenderTypes.hh:143
Definition: Sensor.hh:32
shared_ptr< GpuRays > GpuRaysPtr
Shared pointer to GpuRays.
Definition: RenderTypes.hh:127
shared_ptr< const BoundingBoxCamera > ConstBoundingBoxCameraPtr
Definition: RenderTypes.hh:297
shared_ptr< const ThermalCamera > ConstThermalCameraPtr
Definition: RenderTypes.hh:293
shared_ptr< const ObjectFactory > ConstObjectFactoryPtr
Definition: RenderTypes.hh:361
Represents a off-screen render-texture to which cameras can render images.
Definition: RenderTarget.hh:103
shared_ptr< const SegmentationCamera > ConstSegmentationCameraPtr
Definition: RenderTypes.hh:301
shared_ptr< LightVisual > LightVisualPtr
Shared pointer to Light.
Definition: RenderTypes.hh:183
shared_ptr< const JointVisual > ConstJointVisualPtr
Definition: RenderTypes.hh:325
shared_ptr< const AxisVisual > ConstAxisVisualPtr
Definition: RenderTypes.hh:281
shared_ptr< const Node > ConstNodePtr
Definition: RenderTypes.hh:353
Definition: DepthCamera.hh:34
A render pass that applies Gaussian noise to the render target.
Definition: GaussianNoisePass.hh:35
shared_ptr< Light > LightPtr
Definition: RenderTypes.hh:175
Represents a on-screen render-window to which cameras can render images.
Definition: RenderTarget.hh:119
shared_ptr< ParticleEmitter > ParticleEmitterPtr
Shared pointer to ParticleEmitter.
Definition: RenderTypes.hh:215
shared_ptr< const Mesh > ConstMeshPtr
Definition: RenderTypes.hh:349
Definition: Image.hh:36
shared_ptr< SpotLight > SpotLightPtr
Shared pointer to SpotLight.
Definition: RenderTypes.hh:257
shared_ptr< const Scene > ConstScenePtr
Definition: RenderTypes.hh:397
Poseable Segmentation camera used for rendering the scene graph. This camera is designed to produce s...
Definition: SegmentationCamera.hh:51
shared_ptr< WireBox > WireBoxPtr
Shared pointer to WireBox.
Definition: RenderTypes.hh:273
shared_ptr< const RenderPass > ConstRenderPassPtr
Definition: RenderTypes.hh:377
shared_ptr< const Geometry > ConstGeometryPtr
Definition: RenderTypes.hh:317
shared_ptr< JointVisual > JointVisualPtr
Shared pointer to JointVisual.
Definition: RenderTypes.hh:159
Definition: Camera.hh:49
shared_ptr< Grid > GridPtr
Shared pointer to Grid.
Definition: RenderTypes.hh:155
shared_ptr< const RenderWindow > ConstRenderWindowPtr
Definition: RenderTypes.hh:393
shared_ptr< const RenderTarget > ConstRenderTargetPtr
Definition: RenderTypes.hh:385
shared_ptr< Sensor > SensorPtr
Shared pointer to Sensor.
Definition: RenderTypes.hh:250
shared_ptr< const Heightmap > ConstHeightmapPtr
Definition: RenderTypes.hh:329
shared_ptr< const LidarVisual > ConstLidarVisualPtr
Definition: RenderTypes.hh:341
Definition: Scene.hh:49
shared_ptr< GaussianNoisePass > GaussianNoisePassPtr
Shared pointer to GaussianNoisePass.
Definition: RenderTypes.hh:139
shared_ptr< RenderPassSystem > RenderPassSystemPtr
Shared pointer to RenderPassSystem.
Definition: RenderTypes.hh:231
a map that holds params to be passed to a shader
Definition: ShaderParams.hh:38
shared_ptr< const Object > ConstObjectPtr
Definition: RenderTypes.hh:357
shared_ptr< const GpuRays > ConstGpuRaysPtr
Definition: RenderTypes.hh:305
shared_ptr< const ShaderParams > ConstShaderParamsPtr
Shared pointer to const ShaderParams.
Definition: RenderTypes.hh:404
shared_ptr< Mesh > MeshPtr
Shared pointer to Mesh.
Definition: RenderTypes.hh:199
shared_ptr< BoundingBoxCamera > BoundingBoxCameraPtr
Shared pointer to BoundingBoxCamera.
Definition: RenderTypes.hh:119
shared_ptr< COMVisual > COMVisualPtr
Shared pointer to COMVisual.
Definition: RenderTypes.hh:179
shared_ptr< const SpotLight > ConstSpotLightPtr
Definition: RenderTypes.hh:408
shared_ptr< RenderTexture > RenderTexturePtr
Shared pointer to RenderTexture.
Definition: RenderTypes.hh:239
shared_ptr< RenderTarget > RenderTargetPtr
Shared pointer to RenderTarget.
Definition: RenderTypes.hh:235
Poseable BoundingBox camera used for rendering bounding boxes of objects in the scene.
Definition: BoundingBoxCamera.hh:54
shared_ptr< const GizmoVisual > ConstGizmoVisualPtr
Definition: RenderTypes.hh:321
shared_ptr< Image > ImagePtr
Shared pointer to Image.
Definition: RenderTypes.hh:167
Definition: RenderTarget.hh:37
shared_ptr< LidarVisual > LidarVisualPtr
Shared pointer to LidarVisual.
Definition: RenderTypes.hh:187
Definition: Visual.hh:33
shared_ptr< const Camera > ConstCameraPtr
Definition: RenderTypes.hh:285
shared_ptr< const Text > ConstTextPtr
Definition: RenderTypes.hh:416
shared_ptr< const DirectionalLight > ConstDirectionalLightPtr
Definition: RenderTypes.hh:309
A Ray Query class used for computing ray object intersections.
Definition: RayQuery.hh:63
Represents a infinite directional light.
Definition: Light.hh:121
shared_ptr< const ParticleEmitter > ConstParticleEmitterPtr
Definition: RenderTypes.hh:365
A render pass that applies distortion to the render target.
Definition: DistortionPass.hh:37
shared_ptr< const RenderPassSystem > ConstRenderPassSystemPtr
Definition: RenderTypes.hh:381
shared_ptr< const GaussianNoisePass > ConstGaussianNoisePass
Shared pointer to const GaussianNoisePass.
Definition: RenderTypes.hh:313
shared_ptr< GizmoVisual > GizmoVisualPtr
Shared pointer to GizmoVisual.
Definition: RenderTypes.hh:147
shared_ptr< const Light > ConstLightPtr
Definition: RenderTypes.hh:337
shared_ptr< ThermalCamera > ThermalCameraPtr
Shared pointer to ThermalCamera.
Definition: RenderTypes.hh:115
Shared pointer to Visual.
Definition: RenderTypes.hh:269
shared_ptr< ArrowVisual > ArrowVisualPtr
Shared pointer to ArrowVisual.
Definition: RenderTypes.hh:99
Represents a grid geometry drawn along the XY plane. If vertical cell count is specified then the gri...
Definition: Grid.hh:34
Thermal camera that produces temperature data. An object's temperature can be set through the Visual ...
Definition: ThermalCamera.hh:40
A render pass can be added to a camera to affect how the scene is rendered. It can be used to add pos...
Definition: RenderPass.hh:34
A marker geometry class. The marker's visual appearance is based on the marker type specified.
Definition: Marker.hh:77
shared_ptr< Camera > CameraPtr
Shared pointer to Camera.
Definition: RenderTypes.hh:107
Definition: Object.hh:34
shared_ptr< Text > TextPtr
Shared pointer to Text.
Definition: RenderTypes.hh:265
shared_ptr< Node > NodePtr
Shared pointer to Node.
Definition: RenderTypes.hh:203
shared_ptr< const DepthCamera > ConstDepthCameraPtr
Definition: RenderTypes.hh:289
shared_ptr< const Visual > ConstVisualPtr
Definition: RenderTypes.hh:420
shared_ptr< RenderPass > RenderPassPtr
Shared pointer to RenderPass.
Definition: RenderTypes.hh:227
shared_ptr< RenderWindow > RenderWindowPtr
Shared pointer to RenderWindow.
Definition: RenderTypes.hh:243
shared_ptr< InertiaVisual > InertiaVisualPtr
Definition: RenderTypes.hh:171
shared_ptr< PointLight > PointLightPtr
Shared pointer to PointLight.
Definition: RenderTypes.hh:219
shared_ptr< Scene > ScenePtr
Shared pointer to Scene.
Definition: RenderTypes.hh:246
Definition: RenderEngine.hh:36
shared_ptr< const SubMesh > ConstSubMeshPtr
Definition: RenderTypes.hh:412
Class to manage a particle emitter.
Definition: ParticleEmitter.hh:58
shared_ptr< const RenderTexture > ConstRenderTexturePtr
Definition: RenderTypes.hh:389
A class for creating and managing render passes.
Definition: RenderPassSystem.hh:56
shared_ptr< Capsule > CapsulePtr
Shared pointer to Capsule.
Definition: RenderTypes.hh:151
shared_ptr< ObjectFactory > ObjectFactoryPtr
Shared pointer to ObjectFactory.
Definition: RenderTypes.hh:211
shared_ptr< Material > MaterialPtr
Shared pointer to Material.
Definition: RenderTypes.hh:191
shared_ptr< const RayQuery > ConstRayQueryPtr
Definition: RenderTypes.hh:373
A gizmo that contains rotate, translate, and scale visuals.
Definition: GizmoVisual.hh:34
shared_ptr< DirectionalLight > DirectionalLightPtr
Shared pointer to DirectionalLight.
Definition: RenderTypes.hh:131
shared_ptr< Marker > MarkerPtr
Shared pointer to Marker.
Definition: RenderTypes.hh:195
shared_ptr< Heightmap > HeightmapPtr
Shared pointer to Heightmap.
Definition: RenderTypes.hh:163
shared_ptr< DistortionPass > DistortionPassPtr
Shared pointer to DistortionPass.
Definition: RenderTypes.hh:135
shared_ptr< const ArrowVisual > ConstArrowVisualPtr
Definition: RenderTypes.hh:277
shared_ptr< DepthCamera > DepthCameraPtr
Shared pointer to DepthCamera.
Definition: RenderTypes.hh:111
shared_ptr< SegmentationCamera > SegmentationCameraPtr
Shared pointer to Segmentation Camera.
Definition: RenderTypes.hh:123
shared_ptr< AxisVisual > AxisVisualPtr
Shared pointer to AxisVisual.
Definition: RenderTypes.hh:103
shared_ptr< ShaderParams > ShaderParamsPtr
Shared pointer to ShaderParams.
Definition: RenderTypes.hh:253
